alternative to NEU 1515 1.5y
  • video200
    • 837
    whats the alternative to the NEU 1515 1.5y ? steven is out of stock
    running a DF 33" cyber storm on 6s and a etti 150 race. plans are to run on 642 and\or 645.
    was told that the 580L wouldent fit with water jacket with this mount http://www.offshoreelectrics.com/pro...prod=ose-80230 (wil make suport for the back of the motor)
    been looking at the castle neu 1520 but the rpm`s is starting to get way up there already with the 1515 1.5y
    so any ideas would be apritiated
    klaus
  • Alfa Spirit
    • 2131
    Have a look to TENSHOCK 2250 series or 2750 series
    • BHChieftain
      Fast Electric Addict
      • 1969
      I always try to buy from Steven first because of the great forum he runs here, but sometimes he's out of stock...
      You can look at neu motors home page and find "where to buy" link for other suppliers.
      Chief
      • video200
        • 837
        normaly i always try steven first, he have the best service on your side of the ocean but he been out for a wile now.
        how would the 1521 1y "hold up" vs the 1515 1.5y wont that 1521 be a little much for a DF 33" cyberstorm ?
        • calcagno45
          • Mar 2008
          • 1006
          I would think the 1521/1Y would be the choice to go with. Should run cooler as well.
          • video200
            • 837
            going to ask steven when he exspects water jackets to the 1521.
            still. dont 35 000 rpm sounds a little much on a mono ? or is that cool runnings for a neu ?
            sorry for the "dumb" questions. im used to feiago
            • BHChieftain
              • 1969
              I'm running a 1515 1.5y (1500kv) on my syncron which is around 28-29inches. I can run 4S with a huge prop (so far I've tested up to an x448 with a 6min run and the motor was *cool* to the touch, I get to test an x450 tomorrow...). Or, I can run 6S with a smaller prop.
              Chief
              • video200
                • 837
                i only have 3S batteries so for me 6s is my only real option in my DF 33".
                hows the amp drain when you running large props on 4s for it ?
                i am imagening that a neu wil need less amp to turn the same prop then my nemesis blue 13XL even if the neu is higher KV then the feiago. so then i should be able to prop down and still have about the same speed as i have now.
                • BakedMopar
                  No Mo Slipah
                  • Sep 2009
                  • 1679
                  Jim at southriverrcboats has them in stock.
                  • video200
                    • 837
                    never heard of that store before, thank you gona order one asap
                    • jcald2000
                      • May 2008
                      • 774
                      Get the 1521/1y NOT the 1515 and you will be much happier. Talk to Jim at South River.
                      • video200
                        • 837
                        steven have the 1521 in the store as well :)
                        im just worryed what the exstra KV wil do. the 1521 seems like a beast of a motor
                        • Make-a-Wake
                          FE Rules!
                          • 5557
                          Chief
                          I just ordered the same motor for a 31" mono............what do you think of me running the x642 i have sitting here.........going to run 6s. Anyone have an idea of the amp draw range i may see?
                          • BHChieftain
                            • 1969
                            I have not done any testing on the 6S side yet-- but if it were me I'd start in the 440 range and work up from there... On 4S, the 642 was too small on my boat.
                            -Chief
                            • BHChieftain
                              • 1969
                              This link provides guidance on motor size depending hull type/size and gives battery and prop starting point recommendations.
                              Chief
