Feigao motor question??
  • 99z286spd
    • Jan 2010
    • 266
    I run an Etti 150 opto and a Feigao 580 8L .....On the etti, What PWM ....or motor frequency should i choose? The 8k ....16k....or 32k... I belive my motor is a 1650 kv....but not sure...Thanks for any help..
    8K suitable for most low kv Inrunner Brushless Motor and Outrunner Brushless Motors.
    16K suitable for high kv with Extremely Low Resistance Inrunner Brushless Motors (Such as 3000 kv brushless motor, vibration would be decreased obviously and it can rotate smoothly. However, if this PWM frequency to be selected and the controller will produce 20% more heat ! Please make sure the effective cooling is maintained! (Default Setting)
    32K suitable for High kv with Extremely Low Inductance Brushless motors
    Aeromarine Challenger,Warehouse hobbies Man O War, Traxxas Blast Rescue Rig, AQ UL-1 Yellow, BE REVO,T-Maxx, Vorza, Baja5B, and the latest addition Baja5T, Wife's gunna keel mee!
  • 99z286spd
    • Jan 2010
    • 266
    wow no one knows? anyone? Ive set it on 32k and seems to have cut the heat a little.... esc is 100 and motor is 90 batteries 115. i run 6s 5400mah motor and speedy have seprate cooling lines.
    • m4a1usr
      Fast Electric Addict
      • 2038
      I think no one responded because you seem to have answered your own question in the initial post but here is a general rule thats right from Patrick who of course is of Castle Creations fame.
      PWM settings;
      Higher frequency = hotter ESC, cooler motor
      Lower frequency = cooler ESC, hotter motor
      For the most part you see the default setting of speedos at a low setting and if you go to the Neu web site under recommended settings you will see Neu recommends a low setting. 11/13 khz.
      John
      Change is the one Constant
      • ED66677
        • 1300
        the lower is the better!
        Emmanuel
