Sealed drive shaft?
  • FighterCat57
    "The" Fighter Cat
    • Apr 2010
    • 3480
    Sealed drive shaft?
    I'm building and experimental craft and want to make it as water tight as possible. I'm thinking that a 4mm solid shaft would work, but curious how to seal the transom exit point.
    Perhaps a sealed bearing system?
    Any suggestions, I'm sure there's something out there already.
  • ED66677
    • 1300
    rigid drive shaft are made of :
    the shaft itself let's say it is 4mm OD
    a brass tube (5mmID) that has bushing at each end, bushing are 4mmID
    once the shaft is in the tube, the volume between shaft and tube is filled with any grease via a hole on the ouside of the tube... it is water tight!
    Emmanuel
    • FighterCat57
      "The" Fighter Cat
      • Apr 2010
      • 3480
      So basically, I could use a cable drive strut and not worry about water coming back in the hull. The motor will be mounted at or below the water line in this project. My concern is water coming in through the drive tube.
      If a lubed cable is all it takes then I should be good to go!
      • ED66677
        • 1300
        rigid shaft in a tube is commonly used on scale boat with sub surface prop!
        Emmanuel
        • CornelP
          • May 2009
          • 745
          Try these:
          http://www.offshoreelectrics.com/pro...t+Drive+Shafts
          • FighterCat57
            "The" Fighter Cat
            • Apr 2010
            • 3480
            Originally posted by CornelP
            Yep. That looks like the simplest and least expensive route to go!
            Although if I can get a jet drive/brushless setup... I'm so there!
            • sailr
              • Nov 2007
              • 6927
              I know somebody will say they NEVER get water through their shaft. No matter how hard you try, water seems to find a way in. Put a small piece of sponge under where the shaft enters the boat, next to the motor coupler. This will soak up a small amount.
              Mini Cat Racing USA
              www.minicatracingusa.com
              • FighterCat57
                "The" Fighter Cat
                • Apr 2010
                • 3480
                Yeah, the sponge is a wonderful thing!
                I've been putting extra sponges in my hulls and they've saved me more than once!
                I plan on putting this one in some really really rough water (ocean surf) so minimal leakage and maximum seal is the goal. Hence the jet drive possibility.
                • sailr
                  • Nov 2007
                  • 6927
                  In my bigger boats I put a couple of TAMPAX in there. Works great! You just have to explain to your wife why you have TAMPAX in your car. Haha.
                  Mini Cat Racing USA
                  • Jeff Wohlt
                    • Jan 2008
                    • 2716
                    Still easier to explain that than a condom! I used them for radios years ago. Worked great. I tie the tampon to the anntenny tube...LOL
                    www.rcraceboat.com
                    jwohlt5362@yahoo.com
                    • FighterCat57
                      "The" Fighter Cat
                      • Apr 2010
                      • 3480
                      I guess I asked for it. I was asking to protect my shaft and prevent leakage...
                      OK, Looks like it'll be acceptable to go with a 4mm hard shaft and a sealed rubber boot on a rudder control.
                      • CornelP
                        • May 2009
                        • 745
                        BTW, the worst leak I had was from a jet drive... the body is plastic or GF and the rigid shaft is just glued or forced in. Two runs later on a brushless, you get a bit of play and loads of water.
                        • FighterCat57
                          "The" Fighter Cat
                          • Apr 2010
                          • 3480
                          egads!
                          Maybe I'll just stick with the strut/rudder setup.
                          • Simon.O.
                            • Oct 2007
                            • 1521
                            The solid shaft in a grease fill stern tube is close to perfect for water tightness, I use them in both of my scale boats and even with heavy astern power there is no water ingress.
                            The jet drive is still an option. The jet unit can be mounted outside of the watertight compartment. The rear part of the boat can hold the jet unit in a wet area.
                            A quick sketch !
                            • Xfactor
                              Banned
                              • 861
                              Mc master carr my friend I can tell you expect to pay 100 dollars plus for a sealed flexible motor shaft.
