cutting a flex shaft
  • bwells
    • Jan 2009
    • 842
    I need to shorten a flex shaft and assume that a dremel would be the best way over a hacksaw. Also, I assume that it is best to cut in the direction of the winding as opposed to cross grain. If the dremel is the ticket, what blade would I need and what is it called? Thanks
  • JMSCARD
    • Mar 2010
    • 3444
    I use a standard dremel with the reinforced cutoff blade.... its is a thin reinforced circle type... I buy mine at walmar.... they slice right through.... I don't even pay attention to which way I cut it I just cut straight accross and scuff the edges if thy are sharp... then I have got in the habbit of "tinning" the last 3/4.or so with solder to keep it from "unwrapping".... I've never had flexshaft problems..... now esc's thats a whole other story....LOL.:) good luck.... but its a fairly easy process...
    • tiqueman
      • Jul 2009
      • 5669
      I just cut one a few hours ago. I use the heavy duty cut off wheels. The black glass fiber type, not the brownish red ones that break easily. But those work too.
      • bwells
        • Jan 2009
        • 842
        So a carbon blade verses a metal blade is the way to go? Abrasion wins over metal?
        • longballlumber
          • 3132
          Do not use the metal blade for cutting metallic materials
          use this http://www.dremel.com/en-us/Attachme...l.aspx?pid=409
          or this http://www.dremel.com/en-us/Attachme...l.aspx?pid=426
          Check out Dremel's site they offer a lot of info on which attachemnts do what...
          Later,
          Mike
          • BHChieftain
            Fast Electric Addict
            • 1969
            I just cut one last month using the dremel cutting wheel-- was very easy. WEAR EYE PROTECTION.
            Also, keep your motor away as metal dust will love your magnets.
            Chief
            • electric
              • May 2008
              • 1744
              Yes, wear eye protection. It cuts fine, but those red wheels tend to break and fly off in all directions at high speed on a pretty regular basis. I never have given the wind a thought, just cut it off no problems.
              • Eodman
                • Sep 2007
                • 1253
                After cutting I take the cut edge to a grind stone - turn as you lightly grind any rough edges and then I tin the end also!
                We did it with a Bang!
                Cats Are Where It's At!
                • JimClark
                  • 5907
                  haven't tried it yet but I wonder if you silver soldered the area that is cut if it would hold it together better?
                  Billy Graham
                  • Eodman
                    • Sep 2007
                    • 1253
                    What would be the difference in tinning with plain solder vs silver solder? Just curious -- have done 4 or 5 with regular solder and never had 1 fail!
                    • JMSCARD
                      • Mar 2010
                      • 3444
                      Thats what I do to mine... and what I mean by "tinning" the end.... heat up the end real well and coat with a very light layer of solder... works very well...
                      • JimClark
                        • 5907
                        I have always heard to use silver solder never tried regular solder but then this is only my 2nd boat with a flex shaft. I think Silver solder is much harder than regular solder
                        Billy Graham
                        • pescador
                          • May 2009
                          • 499
                          For 3/16" shafts in my nitro boats I use a pair of cheap ebay cable cutters and touch up the end on a grinding wheel.
                          There seems to be some debate on whether to solder or not I think it was something to do with the end deforming in the collet.
                          I don't solder mine but one of our club members who does uses a piece of brass tubing with one end pinched, heats it with a torch, fills it with solder and then dips the end of the flex in the solder.
                          The cable cutters look like these and they work pretty slick
                          Namba District 16
                          • crabstick
                            • Jul 2008
                            • 954
                            my dremel is getting a bit tired. Last time I cut one, I taped where I want to cut it with electrical tape and cut it carefully through the tape with the hacksaw. Worked mint, didn't unravel
                            Matt.
                            FE, Nitro and Gas racing in Auckland
                            www.rcboats.co.nz
                            • electric
                              • May 2008
                              • 1744
                              I have done it twice where I did not even bother with solder and had no problems with either. I know, you should solder, just pointing out not to get to hung up on it. I would just break out the solder iron and do it for insurance.
