I'm finding that running a higher RPM setup with smaller prop has been producing more top speed and lower peak amp draw with less heat measured post run.
I'm thinking it's because of the nature of electric motors and their tendency to "torque" up to speed and draw large amounts of surge amps while coming up to rpm.
By using a smaller prop and spinning it up, it allows the motor to come up to speed gradually without that hard amp hit from trying to spin up a larger prop. A longer torque curve if you will.
Now, my setups are sport, not racing, but I've nearly hit 60mph on 4s and am only drawing 53 amps peak, with a theoretical max of 40k rpm.
Mind you, I'm using ceramic bearings and wire drives that are made to handle high rpm, as well as a motor rated at 60k rpm.
The major drawback is seemingly slower initial acceleration and some initial cavitation like behavior.
What say the pros on this approach to a low heat, sweet sounding sport configuration? Clearly it is much more demanding on the rotating hardware, but could it be a viable solution for sport setups?
________
Futurama Forum
________
Futurama Forum
