Looks like another myth is busted.
Single-Blade Myth
One of the myths that has been propagated in the aviation community, to the point that it’s almost become gospel, is that the most efficient prop is a single-blade and that all props with higher numbers of blades fall further and further short of this paragon. Did you ever consider that a single-blade prop, developing thrust on only one side of the plane as it revolves, would cause the engine to cone violently in its mounts as it is twisted by the prop?
Airbus Military’s latest turboprop transport, the A400M, has eight-blade props! The Boeing MD-900 helicopter has a five-blade rotor. A popular regional turboprop airliner has a five-blade prop. Hasn’t anybody filled these aircraft manufacturers in on the errors of their ways? In a past issue of a popular aviation magazine, the author of an article on props uttered the same fallacy. He maintained that multiple blades interfere with each other.
When I pointed out to him that at 200 mph and 2800 rpm the blades on my three-blade prop follow three distinct helical paths through the air, and each blade is 25 inches ahead of the previous blade at the same point of rotation, he rather lamely explained that in static conditions interference occurs. Static? Who uses static thrust? Airplanes are meant to fly, not pull tree stumps!
Single-Blade Myth
