fastec amo 2300 kv motor upgrade
  • Jabbo
    • Jul 2009
    • 443
    would an amo 36-50 2300 kv make a good motor upgrade for a PB Fastec? would I need to change out my stock esc 45 amp ( I have a new 60 amp ul-1 esc ,old style with the smaller caps) and what prop should I use? Thanks for any help I want to go faster!!
  • Alexgar
    • Aug 2009
    • 3534
    it think it would i ran a 2200 hc motor and it ran well, presently have a nue 1515 1y with a turnigy 180 (only 80$) check out my vid
    • forescott
      Hopelessly Addicted to RC
      • 2686
      I think a ul-1 motor would be better.(6-poles) Or a castle 1515 would be awesome on 4s!(2200kv) I didnt like the ammo in my supervee. Actually how bout keeping the stock proboat motor, upgrading the esc and running 5-6s??
      • Jabbo
        • Jul 2009
        • 443
        I might go to a hole new set up but trying to stick with 2 cell I have a lot of those batteries to buy all new 3 cells would be to expensive
        • Alexgar
          • Aug 2009
          • 3534
          2 2s will make 4s if you handy with a solder iron make a harness or buy a 4800 kv xcelorin or a 3500 kv velineon and on 2s in a 22" or less hull you should be okay. Better than my first fast electric setup. My first was a brushed 12 turn bby oval master on 7.2 good for about 20 -25 mph
          link
          • Jabbo
            • Jul 2009
            • 443
            I am running 4s in my fastec I'm just trying to find a new motor esc set up to make it faster
            • Alexgar
              • Aug 2009
              • 3534
              hobbycity 6xl on 6s was my first , now 1515 on 6s smoking fast
              neu two links first and last, first has no hatch and ended with a disastrous blow over. Drinking and rc dont mix
              • Alexgar
                • Aug 2009
                • 3534
                sorry about that i used my pb stock motor on a smaller hull with 6s and it smoked a$$ but not for any long periods of time the two above metioned motor killed my escs , so please disregaurd the following if you are runnig stock pb or aquacraft escs
                • Alexgar
                  • Aug 2009
                  • 3534
                  i think something on the 2000kv range should be okay. its an expensive hobby to pick and try, and the higher kv motors burned me out of three esc before i moved up to higher rated parts. Im glad to see someone else running a fastech
                  • Make-a-Wake
                    FE Rules!
                    • 5557
                    If you are still set on using your 60a AQ esc........and 4s I imagine........i would suggest one of these as your esc is the limiting factor here...............you will turning high 20's to 30k rpms with these
                    http://www.offshoreelectrics.com/pro...od=dh-aqug7001
                    I have two of these motors(in 28" and 30" vees) and if it was my boat and my decision, i'd get this, its a powerhouse, and its inexpensive...............first hand experience has me sold on them. 36x56 1800kv
                    http://www.hobbyking.com/hobbyking/s...800kv_Inrunner
                    • Alexgar
                      • Aug 2009
                      • 3534
                      im now on a neu 1y or a hobbyking xl 2200 both on 6s. looking to upgrade my hull soon to a df 29 or 33. to much power for a 26 but i figuired i could always swap up hulls but not down electrics. What do you suggest
                      • Jabbo
                        • Jul 2009
                        • 443
                        That turngiy motor looks great for $20.00 what size cooling jacket does it need. I want to make this boat faster but still controlable. When I get the money I want to do whole build I would have loved to be able to afford Jesseys challanger now but all in good time.
                        • Alexgar
                          • Aug 2009
                          • 3534
                          my pb cooler wouldnt fit they are 35.6 mm or something, the those motors are great get a silicone water jacket
                          • Alexgar
                            • Aug 2009
                            • 3534
                            or this?
                            http://www.hobbyking.com/hobbyking/s...hless_Inrunner
                            • Make-a-Wake
                              FE Rules!
                              • 5557
                              Keep in mind that it is only $20, thats why i posted it, bang for the buck................i was assuming you werent wanting to spend a whole lot on it...........i could be wrong though. The Aq 2030kv is going to be higher quality and faster, its just your $$ and preference. Folks have pushed the turnigy with 5s and 6s in boats with good results.
                              So..........there are better motors you can get(neu's etc.....), it just depends on how much $$ you want to spend!
