Coupler to thrust bearing spacing
  • BHChieftain
    Fast Electric Addict
    • 1969
    Hi,
    Coming off the motor shaft-- should there be any spacing gap between the coupler and thrust bearing, or should these be touching?
    -Chief
  • Jesse J
    scale FE racer
    • Aug 2008
    • 7128
    paper thin.
    you want the thrust bearing to work whenstabout its thrust upon, but not keep the shaft in tension, i.e., don't pull on the shaft to remove all slop before tightening coupler.
    "Look good doin' it"
    See the fleet
    • BHChieftain
      • 1969
      You da man.
      -Chief
      • sundog
        Platinum Card Member
        • Feb 2009
        • 878
        But if you don't pull out some of the slack, how do you know the thrust is all on the thrust bearing instead of the motor bearings? Or do they share the duty?
        Legend 36 sailboat, KMB Powerjet Ed Hardy Viper, ABC jet pwrd BBY Oval Master, ABC Hobby Jetski, NQD Tear Into's, HK Discovery 500, MickieBeez pwrd Jet Rigger!, Davette/Gravtix jet sprint, KMB Powerjet Pursuit, NQD pwrd Jet Catamaran!,Steam pwrd African Queen, Sidewinder airboat, Graupner Eco Power
        • Jeff Wohlt
          • Jan 2008
          • 2716
          Yep...I use 2 pieces of paper. If it actually touches it can create problems
          www.rcraceboat.com
          jwohlt5362@yahoo.com
          • sundog
            • Feb 2009
            • 878
            So Jeff, if you don't have the thrust controlled at the strut (with a bearing or teflon washer), you should have a thrust bearing at the motor to take lateral torque off the forward motor bearing, which isn't designed for that.
            If at the motor, you will take up the slack (except for 2 paper thickness spacing) and the coupler will ride on the bearing? And are you working on my wire drive as you type this? LOL
            • Jeff Wohlt
              • Jan 2008
              • 2716
              The small slack is only meant for not running on the motor constantly...we know it does but with no slack and IF everything is not perfectly flat and true then that can be a problem.
              What wire drive Who are you??? Arkansas? I don't ship there. LOL Yes, Dave it will go out on Sat. Still wondering why that was bent. You have to stop using such a big hammer.
              www.rcraceboat.com
              • BHChieftain
                • 1969
                This could be the source of my overheating rotor...
                Thanks for the tips, I'll do more test runs this weekend!
                -Chief
