hi im new to fe and all ive had thats brushless and uses lipos is a used rustler vxl.
i recently aquired a prather lap cat III of jrcbd in the holiday giveaway and i wanted to make it fe so i was wondering if i could use the fullers hardware rek 3.5 drive and there adapter with the catle creations mamba monster system and a hobby king battery? will i need to use a differend motor mount for the mamba monster motor? if so what mount? and what kv motor what prop what mah battery? 4s or 6s? is 6s enough??? what c rating? also i run in salt water
so my battery will be going in my radio compartment ill be having to cut out my throttle servo mount for extra space for all my electrics to fit includeing my esc. will this cause an issue be cause of cooling even though it has a fan?
thanks in advance sorry for the long post
oh and if the set up i posted is no good what should i do???
-matt
-matt
