Repair Chip in Eco Hull
  • silvermansteve
    • Aug 2009
    • 147
    Greetings. I just noticed a chip in my bare Hydro and Marine Eco hull. I have attached pictures I hope they work.
    I have no experience repairing fiberglass, so I would greatly appreciate any advice and instruction on how to fix this. The simpler the better.
    Thanks!
    Steve
  • HYDROJERRY
    • Jan 2010
    • 2503
    I can't tell what the peice is, yes i see the chip but dont no where on the hull that pic is, but any way usaully you would use thin CA glue on the spot first so it seeps into the fiberglass fibers if they are frayed or well say fuzzy, to harden the fibers back together, then you would use epoxy on top of that( the good kind not walmart kind) do that ouce or twice if you need to build it up alittle, then just alittle body filler over that sand it smooth and prime it and paint it,,,,i did my vegas hull that way and has worked great, the left sponson was busted bad on the inside edge and some cracks on the outside edge very deep to but did it painted it now you cant hardly tell....
