bouncing boat!
water like glass. runnin flightmax 2s 5000's 30c in series. opto etti 150. boat pretty damn heavy def not a light 1. ill have to post a few pics once i get home from school. it was my first true FE, ( on my second right now) i cant ever seem to get this damn mono runnin rightComment
Set your strut angle to neutral (straight) till you stop the bounce."A quick temper will make a fool of you soon enough."
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .Bruce Lee. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .Comment
The image is grossly exaggerated for ease of understanding. the angles need to be very slight."A quick temper will make a fool of you soon enough."
Can you take a pic of the transom & bottom please>??"A quick temper will make a fool of you soon enough."
best i can do for the momentComment
Have you played with the CG at all, you might push it forward a bit just to see if it helps.Comment
Ok, been there done that. Tape some weight to the bow and run it. See if it helps.Comment
Ok, how about prop depth, not angle, but when you put a straight edge on the bottom of the hull how high is the prop in relation to the bottom of the hull. Some times you can lift the prop and settle the hull. You may have to adjust the height at the transom by moving the whole strut up.Comment
