Stuffing tube lube nube
  • sundog
    Platinum Card Member
    • Feb 2009
    • 878
    I use teflon liners in my stuffing tubes and I have been using Gorilla Snawt to lube flex cables but when my chapstick size tube ran out, I thought I'd try Grimracer Speed Grease. Man, this stuff is thick. And when I filled up the stuffing tube on my rigger and turn the prop, there is quite a bit of resistance. I'm sure this is not conducive to high speeds. What th'? Am I just supposed to put a light coating on the cable? Or maybe switch to thick oil? And will that stop water seepage, or is that a real concern? Any thoughts are appreciated.
    Legend 36 sailboat, KMB Powerjet Ed Hardy Viper, ABC jet pwrd BBY Oval Master, ABC Hobby Jetski, NQD Tear Into's, HK Discovery 500, MickieBeez pwrd Jet Rigger!, Davette/Gravtix jet sprint, KMB Powerjet Pursuit, NQD pwrd Jet Catamaran!,Steam pwrd African Queen, Sidewinder airboat, Graupner Eco Power
  • Jesse J
    scale FE racer
    • Aug 2008
    • 7116
    as with any grease, it will reduce viscosity with temps and flinging it around inside your tube. It will only be this thick for maybe a lap then it will reduce to a film.
    I like Jeff Wholt's method of a small amount of grease, like a thin film, then some clipper oil down the tube before each run.
    "Look good doin' it"
    See the fleet
    • gmartin
      • Mar 2010
      • 12
      blue marine grease works well and no water that i can tell my prop is 2-3 inches under water and 1-2 turns its good
      • sundog
        • Feb 2009
        • 878
        Yes I think I'll try the thin film of grease. When packed in there, it slows things down too much. I was just concerned of water entering the shaft if I didn't pack it in.
          • 8011
          Grease should NOT be the method used to keep water out of the hull. Use a short length of fuel tubing around the inner end of the stuffing tube, adjusted so it barely touches the shaft. I use synthetic automotive gear oil on my shafts (no Teflon) and never get more than a drop or two of water in the boat after a long run. Set lots of SAW records with this same technique, and it works great on wire or flex cable.
            • 8011
            • sundog
              • Feb 2009
              • 878
              Thanks Fluid, that's what I was needing to know. Yes, I use that method (actually heat shrink tubing) on the stuffing tube of one of my boats and have had no worries from it.
              • properchopper
                • 6968
                As an alternative to the silicon tube or shrink; try using an antenna cap. Simple, clean & works great !
