I too am having the large spark with my setups... I am running 10s setups in my df sniper and another 40" df clone and a 44" aeromarine cat... is it ok to have the large spark? I am using a schulze 40-160 in the sniper and a hv240 in the df clone, and a Turnigy monster 2000 in my cat... all have BIG sparks.. thought this was normal... I need a "reducing spark for dummies" class if this is a problem as all my setups are running costly esc's I don't want to smoke.......
Spark!
http://mgm-compro.com/pdf/en-antispark-d230808.pdf
I'm gonna try just building a bridge wire to pre-charge the capacitors vs. wiring in a permanant one.
Here's a similar thread:
http://forums.offshoreelectrics.com/...ad.php?t=10487
-ChiefLast edited by BHChieftain; 04-24-2010, 11:35 AM.Comment
Just got some 1/2V 33ohm ressitors from the Shack. 5 of them for .99. Should work find but will know soon.Comment
Attached FilesIMPBA 20481S D-12Comment
Egneg, does this stay in the system while running or just to (prime) the caps? Also, why is no one making and selling these. I know I would invest in a couple. Especially if (like yours) you just plug it in and unplug it, and then plug in your main lead. You would really only need one no matter how many models you have. I am just lazy and not sure where to get the parts.Comment
Egneg, does this stay in the system while running or just to (prime) the caps? Also, why is no one making and selling these. I know I would invest in a couple. Especially if (like yours) you just plug it in and unplug it, and then plug in your main lead. You would really only need one no matter how many models you have. I am just lazy and not sure where to get the parts.IMPBA 20481S D-12Comment
I just made a few. 14 ga wire with resistor between and alligator clips on each end and shrink wrapped. You just stick it on to both ends of connectors before you get ready to tape up and then pull it off and hook the last ESC wire up.
I actually do plan to make some and put them on my site. Figure about $3 would be good. I prefer the clip and no connctors...just more to pull apart.Comment
Here's some newb advice to reduce sparking...
My first connection order when hooking my two 2s1p lipos to my hydra esc was:
1) lipo 1 red to esc red
2) lipo 2 black to esc black
3) (gasp!) lipo1 black to lipo2 black
Result: massive spark.
The next time I tried
1) lipo1 black to lipo2 red
2) lipo2 black to esc black
3) lipo1 red to esc red
Result: big spark, but not as bad as before
Third time I tried
2) lipo1 red to esc red
3) lipo2 black to esc black
This resulted in the smallest spark
I think the 3rd ordering puts the most resistance in the circuit before the final wire is connected since the capacitors are "ahead" of the last connection.
With the 2nd ordering, the capacitors are "behind" the final connection and pull a lot of current quickly before they charge up.
Anyway, with the 3rd ordering the spark is so small I don't feel like I need a spark arrestor...
ChiefComment
