Rigger Help More speed needed
  • bedrock
    • Aug 2009
    • 248
    Hi all
    Can anybody help me with this Carbon Rigger
    I am running a 1521 1y on 6S 1P (Hyperion G3's 5500)
    Prop 646 Etti 200ESC
    Speeds are only at 104km/h
    Also ran this with a H5 with only marginal differance........
    Boat weight is 3.8kg's with batts and motor - length - 1mtr
    Can I prop up ????
    Would going to a 1527 help?
    Would think I should be running around the 115 mark with this setup
    ________
    M70
  • m4a1usr
    Fast Electric Addict
    • 2038
    Originally posted by bedrock
    Can I prop up ????
    If you were running a D winding I would say yes. Since it appears SAW runs are your goal someone who has ran that motor in a rigger should chime in. Maybe Brian? I have something similar is size and weight but I am using a 1521/1D and I have prop'd up to a 2150. Respectable speeds but terrible heat. I settled on a V947. The H series seem to be ideal for what you are doing. BTW very nice boat!
    John
    Change is the one Constant
    • RandyatBBY
      • Sep 2007
      • 3915
      That is the motor I went 88MPH on 8S in the 34inch War Eagle at the last SAW's. Have you looked at the ride pads? blue printing is good for 6 to 8 MPH.
      Randy
      BBY Racing
      • bedrock
        • Aug 2009
        • 248
        Thanks
        Randy - Can I run this motor on 8S for SAW?
        Will look at the pads
        thanks
        Dean
        ________
        Honda Integra History
          That's a mighty small motor for 8S for a new SAW racer. You should be able to get well into the 70s with that motor on 6S IF the rigger is properly designed and set up. Some riggers will never go real fast due to poor design or setup.
          You do not have enough prop pitch, the H5 has about the same pitch as the x646 does, no surprise it's no faster. You probably do not have enough timing advance either. Both will doom you to slow speeds even with a great rigger design.
          Set the timing for 15 degrees and try a 2140 or 2045 prop. These have a lot of lift so move the CG back and run the strut dead flat. Confine yourself to two passes, then bring it in to check temps. What size of pond are you running on? Is it long enough to go real fast before you shut down or turn?
          I ran the 1527/1D in my 6S cat over 80 thought the traps in LA....
          • bedrock
            • Aug 2009
            • 248
            Thanks for your input
            Runs have been over a long distance its a river say 250mtrs at least...
            Will look at the props you suggested - are the Octura? I have a X455 not sure if this will help?
            Re: Timming advance Its a[B] Etti 200HV [/B - ]so think I can advance the timing to 15deg....
            thanks
            Dean
            ________
            Cheap vaporizers
            • Chris Harris
              • Oct 2007
              • 182
              First of all if top speed is what your looking for here X props are not going to get you there. I agree with Fluid here you need lifting props as their blade shape and pitch profiles are more suited to hydros, especially riggers.
              The other thing I noticed in the pictures is that the angle of attack on the sponsons
              looks extremely low. Is the AOA adjustable? If it is try giving them a little more angle.
              Make small adjustments at a time. Water drag is the absolute enemy of speed.
              If you can get the boat running more loose you will see a dramatic difference in speed. Of course there is a trade off here, too much angle and the boat will blow off.
              It's all about finding a balance.
              Chris
              I.M.P.B.A. Record Holder P-Hydro 111.001mph Q-Hydro 120.192mph S-Hydro 139.233mph
              • bedrock
                • Aug 2009
                • 248
                Thanks guys
                Does anybody know who sells these props are they Octura/ ABC?????
                2045....... 2140
                Dean
                ________
                Clear trichomes
                • jcald2000
                  • May 2008
                  • 774
                  Octura
                  • bedrock
                    • Aug 2009
                    • 248
                    Hi all
                    Well hope somebody can help further
                    Went out today and only got 104k\hr max GPS
                    1521 1Y
                    Hyperion G3 5500 - 6S - 2x 3S in series
                    H5 prop - - - Balanced
                    Etti 150 ESC timing to 15Deg.
                    Would think I should be around the 120mark at least
                    will try a lifting prop tomorrow see if I cant get some more from this baby
                    Dean
                    ________
                    Buy aromed vaporizer
