Hydro hooking in turns
  • HappyOne
    • Jul 2008
    • 179
    I have a Vac-U-Pickle that I am tweaking the setup on. I have the straightaway ride nice and smooth and fast but she "hooks" in the turns. It is as if gradually adding rudder has no effect and then all of a sudden it catches and hooks the boat.
    How do I fix this?
    Grand River Marine Modellers, el Presidente
    IROC VUP, 25" Prince Mono, Mini Hydro, Classic Barrel Back, brushless Mini Rio and two Nitro Tunnels
  • Eodman
    • Sep 2007
    • 1253
    Semtex & a blasting cap????
    We did it with a Bang!
    Cats Are Where It's At!
    • Jeepers
      • May 2007
      • 1973
      how long is the rudder?
      • AlanN
        • Mar 2008
        • 334
        It has more to due with cg and the shape of the turn fin than the rudder.
        Post some pics of your setup.
        • HappyOne
          • Jul 2008
          • 179
          It's a Smock racing IROC model. It ran great when I got it but some how I must screwed it up.
          http://www.vac-u-boat.com/PickleSmockBuildPage.htm
          • Rumdog
            • 6453
            Did the turn fin get kicked back?
            • HappyOne
              • Jul 2008
              • 179
              That's a thought. I will check it against Doug's pictures.
              • crabstick
                • Jul 2008
                • 954
                +1 for turnfin
                Also check your rudder EPA
                Matt.
                FE, Nitro and Gas racing in Auckland
                www.rcboats.co.nz
                • Ctonez
                  • Jul 2007
                  • 404
                  Every VacuPickle I've seen does this occasionally. My solution was to not let off the trigger as much going into turns, so far - so good. I read on RRR that it may have something to do with when the boat slows and the prop torque increases, but I'm open to anyone's input on this as well...
                  Mine hooks about once every three heats, so I figure it's likely my driving is just crappy...
                  • Rex R
                    • 992
                    mine did a flat 360 on the front straight...fellow racers told me that they were not awarding style points .
                    rex
                    • Doby
                      KANADA RULES!
                      • 7280
                      Learn to drive................
                      • Ctonez
                        • Jul 2007
                        • 404
                        wow...good one.
                        glad we cleared that up.
                        • Meniscus
                          Refuse the box exists!
                          • Jul 2008
                          • 3225
                          Just a thought, but I've heard of riggers doing this when the rudder doesn't have clean water, such as the wash of the prop. I'd also check to see if the turn fin is still straight and ensure you aren't compensating for the off axis drag with the rudder trim. I had a similar issue when I didn't get my turn fin on a Viper truly straight after hitting a carp.
                          Another thought, although unlikely, is that perhaps the prop is hopping due to too much lift. When the stern hops, the turn fin catches and could result in the hooking you are describing.
                          I'm not saying any of these are the case, but simply throwing some additional ideas out there. I do not and have not owned this model. Doug Smock (D.Smock) can probably provide the best input regarding this specific model.
                          Hope this helps.
                          • HappyOne
                            • Jul 2008
                            • 179
                            So kind...
                            • ED66677
                              • 1300
                              could it be that the servo is not powerfull enough? just an idea!
                              Emmanuel
