As usual I have been up and down the pages and have a fair idea of what I need.
I need to replace the 23"Balsa cat that had a fatal run at the weekend and I am now looking at a hull between 18-21" loa. As I like the long overhang and a prop well aft of the sponson rear, the effective length of the hull will be closer to 18"
I have run a Feigao 12S(2800+kv) motor on 4S to a 432 prop before in the 23"hull.........It was well fast.!!
I am keen to have a go with an outrunner and broaden my knowledge base. They are very popular and very cheap. That works for me !
Here is a possible setup.
This motor
My reading tells me that there are two 450 size Typhoon motors and the shorter one is close to 4000Kv and the longer one is 3600Kv.
Now I can run the lower Kv motor on 4S or the higher Kv on 3S and both will give me wicked rpms..............so far I am happy.
If I feed either of these to a 432 ( my prefered prop for this build ) what sort of Amps am I likely to see ?
This will help me choose an esc. 60, 80, or 100+A and then my packs.
Do I need to prepare for a 60A load or a 120A load?
Is there a way I can convert data from FEcalc for estimates, say use a 380 can ?
Keep in mind I am a solo sport boater and like close to SAW setups.
Don't be afraid to shoot me a PM if you are unsure of your data. I will take any and all input and make a decision then.
This motor
