60/40 or 40/60?
  • BHChieftain
    Fast Electric Addict
    • 1969
    60/40 or 40/60?
    Sigh... too many *&%$ choices at the hardware store...
    For solder, do I use 60% tin/ 40% lead rosin, or 40% tin / 60% lead or does it matter (I know to avoid acid )
    Secondly, any problems mixing these on a joint? ( I was using 60/40 , but I need to rework, ok if I use 40/60 to supplement)
    -Chief
  • m4a1usr
    • 2038
    Use the 40/60. Its my preferred solder. You can mix the 40/60+60/40 if you have to. Solder with a higher tin content melts at a lower temperature. So the 40/60 is good and strong and the melting temp is low enough IMO (460degF). Just my 2 cents.
    BTW, I prefer to use solid core. Why? Because I dont like the cheap brown rosin they inject into the center and because its solid a roll lasts forever if you buy it in a large enough diameter. I like 1/8th". And I buy a jar of greenless rosin paste, 4 oz container, and it lasts forever too.
    John
    Change is the one Constant
    • tth
      • Apr 2008
      • 1510
      I agree with John. I use solid solder with paste.
      • BHChieftain
        • 1969
        As always, thanks guys,
        -Chief
        • bigwaveohs
          • May 2009
          • 535
          -Chief
          The details...
          Tin/Lead Melting Point
          40/60 460 degrees F (230 degrees C)
          50/50 418 degrees F (214 degrees C)
          60/40 374 degrees F (190 degrees C)
          63/37 364 degrees F (183 degrees C)
          95/5 434 degrees F (224 degrees C)
          I let the dogs out...
