I have a question for you guys, I just went to 18cells (IB4200's) in my OM29 with a 11XL,K42 prop and a Baracuda 125. I have run the set up 4-5 times now in everything from flat water too pretty big waves. In flat water the set up seems to be great, motor and ESC are completely comfortable to touch and the batterys are not much above ambient temp. As the waves build so do the temps, now I know running partial throttle will heat up the ESC, the reason I went with a B125 thinking that I would be pulling somewhere around 50ish+ amps (in flat water I seem to be pulling somewhere around 45-50A average calculating out run time VS. Mah put back into the pack) . Last night I was running in some pretty big waves so most of the time was spent at 50-75% throttle with bursts of WOT. The boats seemed to spend as much time out of the water as it did in the water and after 4 or so minutes I think I was starting to thermal the ESC, it would shut down for a few seconds and then go again. I ran her for a another minute (total run time was just over 5 minutes) and when I opened her up the motor and ESC were pretty warm, I was able to hold the motor for 10 seconds or so before it became uncomfortable (very scientific I know) and the ESC was a bit cooler but still warmer then I have experienced so far. So my question is does the loading and unloading as well as partial throttle heat a motor more then running pretty much flat out? I guess it could also come down to the fact that when there are waves I spend more time accelerating then when the water is flat and I can pretty much punch it and hang on.
Cheers,
Jim
Cheers,
Jim
