Stuffing tube help needed
  • boater76
    • 505
    I can't get my teflon tube for .130 cable into the 7/32 brass tube I have. How the hell do I get it in there? It wont budge.
  • Diegoboy
    • Mar 2007
    • 7244
    Are you sure it's a 7/32 tube? Are you sure it's a 0.130? Mine all fit a bit loose
    • Jeff Wohlt
      • Jan 2008
      • 2716
      Stretch it a bit and then slide it in.
      www.rcraceboat.com
      [email protected]
      • boater76
        • 505
        I got the tube and teflon from ose. No mistake about either.
        • m4a1usr
          Fast Electric Addict
          • 2038
          Did you de-burr the end of the stuffing tube after you cut it to length?
          John
          Change is the one Constant
          • boater76
            • 505
            I didnt even cut it yet. So there are no burr's.
            • m4a1usr
              • 2038
              7/32 is like .21 something. I dont have a chart in front of me right now. You must be using 5/32? Normal teflon line should slide right in like Diego said in 5/32 tubing. I wonder if you got an odd size teflon?
              John
              • Jesse J
                scale FE racer
                • Aug 2008
                • 7116
                you might measure the od of your teflon and id of brass with calipers to help understand how much we are talking - Jeff's point is good, sometimes the teflon is juuuuusst a hair big and stretching it actually decreases the diameter.
                "Look good doin' it"
                See the fleet
                • boater76
                  • 505
                  I will check the measurements out tonight.
                  • ezhitz
                    • Aug 2009
                    • 428
                    I found it easier to pull the teflon though instead of pushing it. Hook the end with a stiff wire
                    and add a couple drop of thin oil then pull it though.hope this helps.
                    :canada
                    • boater76
                      • 505
                      Measured od of teflon was about .183 and the brass id was bout 5mm or 1.79
                      • Jesse J
                        scale FE racer
                        • Aug 2008
                        • 7116
                        giver a stretch and maybe some oil, oughta slip in..
                        See the fleet
                        • Jeff Wohlt
                          • Jan 2008
                          • 2716
                          I have even run sand paper down it to remove a few .000
                          Tight is good! I have seen some want to actually spin in the stuffing tube.
                          www.rcraceboat.com
                          [email protected]
                          • boater76
                            • 505
                            Ok will try them ideas. Thanks.
                            • m4a1usr
                              • 2038
                              That brass tubing id is too small if true. I measured my stock and its .191 id and the octura OC130L-24C .130 flex/teflon combo slides right in my tubing.
                              John
