Mount for REK unit
  • rchippie
    • Jan 2010
    • 567
    Mount for REK unit
    I have a REK lower unit, that im going to use on my VS1 . It came with a dubro mount . Is this a good mount or should i get a different one ?. If a different mount is recomended . Which one would you recomend & were can i get it . Thank's
  • westbeach
    OSE Rocks!
    • 951
    Capt Vic on International waters make an adjustable mount for 3.5 and 7.5. I picked one up for a 3.5, even though I don't have a tunnel hull right now. His product is top notch.
    HPR115 x2 ,Dark Horse Shovel, Delta Force CyberStorm, Delta Force Sniper 23-RTR:
    • westbeach
      OSE Rocks!
      • 951
      My gold Hi-Jack mount.
      • rchippie
        • Jan 2010
        • 567
        Does he have a web site ?.
        • ozzie-crawl
          • Sep 2008
          • 2865
          the hijack plates are fairly expensive i think, these from ose work well http://www.offshoreelectrics.com/pro...rod=hpi-obmm35
          the 4 main bolts dont need to move for adjustments like some do, there is 2 bolts that allow up and down adjustment as well as angle
          • rchippie
            • Jan 2010
            • 567
            Scott
            I like that one . I just want to make sure it would work with the rek unit. Also do you think it's better than the dubro mount or is the dubro mount good enough ?.
            • westbeach
              OSE Rocks!
              • 951
              No website. I can email him if you're interested. JLMK
              • ozzie-crawl
                • Sep 2008
                • 2865
                i havent used the dubro mount so cant say, i have only used the one i posted and it works great
                • eboat
                  • Aug 2007
                  • 693
                  I just used the mount that came on the REK
                  The 4 mounting holes had slots in them so it could be moved up and down
                  I just loosened the lower bolts to put a wedge under them to change the angle at the prop but in the end I just ran it with the mount flat on the back of my boat
                  • ozzie-crawl
                    • Sep 2008
                    • 2865
                    thats why i like they hyperformance mount as i dont like the idea of undoing the bolts that go into the hull with a chance of it leaking,height and angle are just 2 bolts very easy to adjust
                    • ice329
                      • 792
                      The Hi-Jack plate is really the one to get. You can raise or lower the motor along with tilting it in or out pretty easy, sets the motor back further and the eye candy factor alone is worth the xtra 20. Here is his paypal email, not sure if its also his email but it probly is. This is what i used about a year ago to contact him G/L [email protected]
                      • Steven Vaccaro
                        • 8721
                        Can you post a picture of the Dubro mount?
                        • rchippie
                          • Jan 2010
                          • 567
                          STEVE Here you go.
                          • Steven Vaccaro
                            • 8721
                            thanks!
                            • eboat
                              • Aug 2007
                              • 693
                              Just use the mount you have
                              Once you get it adjusted so the boat works well you will not change the settings anyway
