FYI - - Neodymium Magnets
  • FloatDaBoat
    Bare Bones Fabricator
    • Sep 2009
    • 368
    Neodymium Magnets: Major Source - Wikipedia
    A neodymium magnet (also known as NdFeB, NIB, or Neo magnet), a type of rare-earth magnet, is a permanent magnet made from an alloy of neodymium, iron, and boron to form Nd2Fe14B. Neodymium magnets are more powerful than samarium cobalt (SmCo) magnets, which were the first type of rare earth magnet to be commercialized, and are currently the strongest type of permanent magnet.
    The automotive industry is currently sucking-up the world’s available supply of neodymium (& other rare-earth metals) for the electric motors and batteries used in ’Hybrid’ vehicles. Plans are already in the works to open new mines to increase the supply of these RARE metals. This shortage will probably have an impact on RC usage of these magnetic materials, i.e., availability and/or cost.
    Neodymium is alloyed with terbium and dysprosium (two other rare-earth metals) in order to preserve its magnetic properties at high temperatures.
    Sintered Nd2Fe14B is highly liable to corrosion. One cubic centimeter will completely oxidize after exposure to air for 1 year. To prevent corrosion most of the magnets get coated. Nickel plating or two layered copper nickel plating is used as a standard method, although plating with other metals or polymer and lacquer protective coatings are also in use.
    If the coating used on the rotor becomes defective & allows air to come in contact with the neodymium compounds, just say bye-bye to that rotor’s magnetic capabilities in a relatively short period of time. This info makes me wonder about the various manufacturer’s claims as to the actual composition/quality of their motor magnets.
    Sintered - Full Density magnetically aligned powder is formed into dense blocks which are then heat treated (the powder is heated in a pressurized mold to just below the melting point until the molecules fuse together), cut to shape, surface treated and magnetized.
    Bonded - Spin Melting creates a powder, to which a bonding agent is added, to form the magnet into the desired shape.
    Some important properties used to compare permanent magnets are: remanence (Mr), which measures the strength of the magnetic field; coercivity (Hci), the material's resistance to becoming demagnetized; energy product (BHmax), the density of magnetic energy; and Curie temperature (TC), the temperature at which the material loses its magnetism. [See Attached].
  • m4a1usr
    Fast Electric Addict
    • 2038
    Thats actualy a pretty good topic and as an investor I have already added a stock or two to my portfolio. Stocks in mining traditionaly dont yield high returns so they can be quite affordable because its a long term investment but as you pointed out rare earth metals are becoming a hot commodity. There is a pretty good chance that as the automobile industry and electric cars popularity grows the futures market for this will be prime for rapid expansion. Big bux in returns.
    John
    http://seekingalpha.com/instablog/53...will-fight-for
    Change is the one Constant
    • FloatDaBoat
      • Sep 2009
      • 368
      One location for a future rare-earth metals mine is in Canada. If enough ore’s mined & relocated across the globe, it might cause a shift in declination of the Earth’s Magnetic North Pole. A perfect opportunity for all those High Rollers in the Stock Market to invest in Map Making Companies - - HAW !!!
