Plasti dip or DP270 on UBEC?
  • Lasse Baardseth
    • 69
    I want to waterproof my ubec.
    What do you suggest?
  • sailr
    • Nov 2007
    • 6927
    Everybody says DP270.
    Mini Cat Racing USA
    www.minicatracingusa.com
    • Jesse J
      scale FE racer
      • Aug 2008
      • 7117
      is there a reason NOT to use plasti-dip??
      I have several this way that I haven't used much but have not caused any problems.
      "Look good doin' it"
      See the fleet
      • Lasse Baardseth
        • 69
        Ok. Thanks!
        • RandyatBBY
          • Sep 2007
          • 3915
          I prefer Conformal coating and it does not void the warranty.
          422C is a 1-part, acrylic-silicone blend waterproof conformal coating that cures to a durable, flexible and smooth finish. It is easy to apply and can be handled in only 10 minutes. It may be removed with appropriate strippers, or soldered through for repair or rework.
          Randy
          BBY Racing
          • sailr
            • Nov 2007
            • 6927
            I think the DP270 gets down into the nooks and crannies better and isn't easily damaged like the plasti dip is. Just my opinion though.
            Mini Cat Racing USA
            • sailr
              • Nov 2007
              • 6927
              Is that an aerosol can? It says you have to spray it?
              http://www.mgchemicals.com/products/422a.html
              Mini Cat Racing USA
              • m4a1usr
                Fast Electric Addict
                • 2038
                It is a thin/light coating applied by aerosol can. Great stuff. Dont know if true but its supposedly the brand Castle uses on their speedos. I have been using it for a couple years and never a problem. Silicone Conformal Spray.
                My own preference would be to use the DP270 (I already have used this to waterproof my Hextronic UBEC's) but as long as the plasti dip had no conductive properties I see no reason it couldnt be used.
                John
                Change is the one Constant
                • JimClark
                  • 5907
                  Then use this it is brush on
                  Billy Graham
                  • daveives
                    • Jun 2009
                    • 109
                    I now use Permatex Ultra Blue RTV Sensor-Safe Silicone
                    I tried tool-dip, then liquid tape (2 different brands), then Zap thin epoxy heated, then conformal coating (3 coatings) to waterproof ESC's that actually get submerged when the boat is not running. I run outboard tunnel hulls. All of these waterproofing efforts failed. Now use Permatex Ultra Blue RTV Silicone Sensor-Safe Gasket Maker Item# 81724. It takes silicone to bond correctly to the silicone wire insulation and silicone cooling tubing. Epoxy eventually leaks along the silicone wire insulation, killing the esc. The other methods eventually fail for me after typically 8 sessions or so at the pond.
