Do Turginy balance connectors match with Hyperion chargers with out adaptors ?
Gawd only knows. I wish they would standardize the danged balance connectors!Mini Cat Racing USA
www.minicatracingusa.com -
I'm pretty sure they don't.
http://www.allerc.com/product_info.p...oducts_id=3159
Turnigy uses a JST-XH balance connector. Looks like you need the HP-LB10-XH balance adapter.Comment
Billy GrahamComment
Turnigys have the JST-XH balance tap
Hyperion uses a different one you need an adaptor or a JST-XH balance board for your charger
Like it was said above in post #3 you need a Hyperion HP-LB10-XH balance board these other guys that say they will are totally off base and yo are gonna screw up your batteries"Our society strives to avoid any possibility of offending anyone except God.
Billy GrahamComment
I am so sorry. Here I was talking out of my arse again. I got my balancing adapters mixed up. I use a couple of different ones.
It appears that you use the adapter for align. This is the board that I use with my Turningy 2s packs.
I hope this helps.Attached FilesComment
This is the one I use with my Turnigy lipos and Hyperion 606 charger. I purchased this XH version from ALL E RC when I purchased my charger.
http://www.allerc.com/product_info.p...oducts_id=3159Attached FilesComment
I bought this last week. I did use the one detox posted before. I hooked it up 2 2s zippy's and set the charger to 4s. Everything checked good and began to charge at 4amps, but I only let it charge for about 3 minutes to verify it worked. Haven't used it since I've been out of town alot lately, but it appears to be a good $6 investment. Nice part it comes with several different balance plugs for different chargers. It works on hyperion, but did not fit my Triton.Comment
