hydra 240hv
  • RIPFENCE
    • Sep 2009
    • 1332
    hydra 240hv
    how much does it cost to send a 240hv in for repair? the reason why i am asking is because i have one that i bought off mike martin unused and i cannot get it to work..i have spent hours trying different settings on my radio but there is no sound or life from the 240...all i get is a red flashing led light...i might try to sell it on the swap shop if someone wants to send it in for repair..too bad there is no evidence of smoking on plug in like some have experienced..do not know what to do
    "FE" STANDS FOR FRUSTRATING EXPLOSIONS
  • hydromaddicted
    • 83
    Did you go through set up?
    3.0 Calibrating the HYDRA™ to YOUR transmitter:
    IMPORTANT NOTE: Calibration is required for the very first use of the
    HYDRA™ or whenever used with a new/different transmitter.
    The HYDRA™ contains a throttle calibration feature that you'll want to use the first
    time you power it up with a new/different transmitter. Performing this exercise will
    teach the controller how your transmitter works.
    • Disconnect battery
    • Hold full throttle on your transmitter
    • Connect battery
    • HYDRA HV™ flashes LED and rings once
    • Wait 2 seconds
    • HYDRA HV™ flashes LED and rings 4 times indicating full throttle
    measured
    • HYDRA HV™ flashes LED while beeping, indicating it's time to push full
    brake
    • Push full brake
    • Wait 1 second
    • HYDRA HV™ flashes LED and rings 4 times indicating full brake
    measured
    • HYDRA HV™ flashes LED while beeping indicating its time for neutral
    • Relax trigger to neutral (center)
    • Wait 1 second
    • HYDRA HV™ flashes LED and rings 4 times indicating neutral measured
    • Wait for 1 second
    • HYDRA HV™ will flash LED and ring twice indicating that it is armed
    • biasca09
      • Apr 2009
      • 15
      Here is a link to the castle creations flat rate repair page. these are the prices for non-warranty repairs. If you can get it covered under warranty then just shipping costs. Give them a call, they have always been very helpful in my dealings with them.
      • BakedMopar
        No Mo Slipah
        • Sep 2009
        • 1679
        Maybe a stupid resonse but are you using a seperate BEC? HV's are opto and an external BEC or RX pack is needed.
        • RIPFENCE
          • Sep 2009
          • 1332
          yes my receiver is getting power through a bec and my servo is working perfectly thanks
