Cutting Motor Shaft
  • Drag Boat Bob
    • Apr 2009
    • 304
    Cutting Motor Shaft
    What is the best way to cut a flat spot on a motor shaft (for coupler set screw)?
    I was going to use my dremel, but thought that there may be a better way.
    Thanks in advance...
  • Chilli
    • Jan 2008
    • 3070
    I always use the dremel. I've used the sanding drum and the chain saw sharpening stone. Both work great.
    Mike Chirillo
    www.capitolrcmodelboats.com
    • m4a1usr
      Fast Electric Addict
      • 2038
      I use a dremel too. Doesnt take but a couple passes with a steady hand to cut a flat. All you effectively need is the diameter of the set screw.
      John
      Change is the one Constant
      • illz302
        Banned
        • Sep 2009
        • 191
        Same here just be carefull not to slip or it will most likely cause your setscrew to be able to slide back and forth on the shaft...........
        Gotta be able to learn from your own mistakes.
        • Rex R
          • 992
          tape(or otherwise cover) any holes in the motor can to keep metal filings out of the motor.
          • Rumdog
            • 6453
            Make sure that if your motors end caps are open/ have foles in them to put some tape or something over the openings. You dont want tiny metal shavings goin in the motor!
            • Rumdog
              • 6453
              lol, too slow I was!
              • Steven Vaccaro
                • 8723
                Someone once said to stick the motor in a zip-lock bag and poke the shaft through it. I use this method now and its great.
                • Drag Boat Bob
                  • Apr 2009
                  • 304
                  What a great idea! Going to give this a try.
                  Thanks again to everyone...
                  • FloatDaBoat
                    Bare Bones Fabricator
                    • Sep 2009
                    • 368
                    Here’s a jig I fabricated from quarter inch poplar, an old screen door hinge, & some 2 inch Velcro. It’s original purpose was for cutting stainless tubing, but I’ve used it to grind set screw flats on prop shafts. With slight modification, It’d work great for motor shafts as well. To achieve a wider notch, just epoxy two cutting wheels together (two 1/16 inch thick wheels = 1/8 inch - - should be fine for a motor shaft).
                    • Drag Boat Bob
                      • Apr 2009
                      • 304
                      Now that's ingenuity...
                        Won't be fine for a motor shaft. You will get a notch with a raised portion in the middle which will have to be ground down separately for the set screw to seat adequately. Ask me how I know....
                        • FloatDaBoat
                          • Sep 2009
                          • 368
                          If the two wheels are Tightly Clamped Together while the epoxy cures, there will be no ridge in the middle - - ask me how I know . . . .
