So I got this hull from the swap shop last week.
http://forums.offshoreelectrics.com/...ad.php?t=12966
And after arrival determined it must be a HOTR. Now Im painting a Rigger for a friend of mine which is a H&M and to my suprise, that hull has the same insignia paper stamp resined into the canopy.
I guess it would be easy to duplicate this and glass it into whatever hull you had.. but how can I find out if mines an actual H&M or a HOTR? Are these two hulls EXACTLY the same! As in, did HOTR infact pull the Agitator and leave it EXACT? The layup of the riggers canopy is a woven cloth. The Cat has a woven hull, but matt hatch. The cat also seems to have a bit darker yellow resin than the H&M rigger. Like a Poly rather than an epoxy. The hatches compared at the thick part of the resin behind the front verticle face of the scoop shows like epoxy in the rigger (a cloudy whitish blue) where as the cat is yellow.
Im still favoring it is a HOTR that someone at one point sold off as a H&M knock off.
"Thegreat1" that I purchased the hull from stated it was a HOTR. He in no way at all represented it to me via PM or on the swap shop as a H&M. Just wanted to make that clear for his sake. He was "great" to deal with.
EDIT:
Oh, and the right sponson was slightly kicked in. The left was less than a 32nd off. With some heat and wedges they are now perfectly straight.
Also the hull did have about 3/32 of twist in it. It is now almost straight.... lil more to go.
EDIT:
