I'm building a P-Spec Tunnel Hull and need a little help. I'm using a Aquacraft 60amp ESC, and want to know if there is any problem in extending the leads on the battery side? Can you add a certain amount without causing problems with the ESC?
Aquacraft 60amp ESC?
Tags: None
I would think you would be adding a little resistance only.
I extended my AQ ESC Batt wires in my SV a couple inches w/ no problems. -
Add a couple of 25v 370mf capacitors to help.......* BBY Lift Master RIgger * Insane Gen 2 Cat * Aeromarine Avenger Pro Twin * Delta Force Cyber Storm * Delta Force 41" Mono * H&M Viper II * H&M Intruder * OSE Raider Hydro * Whiplash 20 * Brushless Mini Rio *Comment
I would extend the motor leads instead..................the main resistance comes from the Battery leads.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
