i have a tenshock 40a esc ? With problems ?
  • lucozader
    • May 2009
    • 144
    i have the above esc
    i got it last week
    i am using a pistol transmitter
    i set it up as suggested in the instructions
    it won't go to zero rpm when the throttle isat neutral
    it goes from slow to fast
    but not from zero to fast
    any tips ?
  • ozzie-crawl
    • Sep 2008
    • 2865
    they are not designed for a pistol grip, with some playing around you can get it to work.
    you need to move your zero point further back using the trim, or you need a pistix adapter
    • lucozader
      • May 2009
      • 144
      i got a pistix off ose
      but i burnt it out messing around with another boat
      i'll try to re adjust the trim
      thanks
      • sailr
        • Nov 2007
        • 6927
        That's odd. Tenshock ESC's are designed to work with pistol style transmitters but not sure about ones from Europe. In a lot of the world, stick type transmitters are the preference so it's possible the Tenshock units made for the European market are not set up for pistol style transmitters. A Pistix is definately the way to go.
        Mini Cat Racing USA
        www.minicatracingusa.com
        • FishMaxx
          • May 2011
          • 1
          I just bought a minicatracingusa.com mini eco, it appears I have a European Tenshock ECS.
          Is there a fix for this besides the pixstix?
          • sailr
            • Nov 2007
            • 6927
            The Only radio having problems with the esc is the spektrums. Adjust the EPA's . Should cure the problem.
            Not sure where you got the idea the esc's from us are any different than those in Europe. All the same.
            Mini Cat Racing USA
            • drkdgglr
              Dutch Electric Powerboats
              • 27
              I had this esc, and it works fine with a pistol style transmitter (3pk).
              Btw: I think these are just rebranded swordfish 40a esc's.
              MHZ WaveFighter
