Low voltage cutoff equipment?
  • Steven Vaccaro
    • 8723
    What specific equipment are you guys using for a low voltage cuttoff device?
  • SJFE
    • 4735
    I ordered mine from AllBattery direct. It's the Dimension Engineering lipo shield. Up to 5 or 6 cells auto detecting & runs inline with the rx. 19.99. I've used it 4 or 5 times. No problems. :)
    • Doozie870
      • 828
      Im looking real hard at the, "apogee loud obnoxious lipo alarm with led", surely I cant screw up with that!
      • SJFE
        • 4735
        The alarm is nice but the unit will cut the power and start pulsing power or reduce the current so you can bring her home.
        • Rex R
          • 992
          cc barracuda 80 for my 2s2p setup
          • properchopper
            rcgoatbuild@snotmail.com
            • 6968
            Re :
            Good thread ; I need to learn more about this [ lipos installed/charged, will run
            1st time next Sun]. I programed the 'Cudas to 14 volts LVC [ 4S paks ; 4 X 3.5 =14]. Was advised by some lipo-savvy guys to do this BUT I'm open to other input.
            With this new $$$ investment I can't afford to screw anything up !
            • Steven Vaccaro
              • 8723
              Thanks for all the input so far. Specifically I'm looking for a lv for a supervee.
              • SJFE
                • 4735
                That is where I tested my unit. I used it with the stock SV power system & the poly rc 7.4 s2 3600mah 12-16c I bought from Mr Hill. So I was running an s4 setup @ 14.8 volts on a 45 mm prop. I was pulling 38 amps spiking to 60 in the turns. The packs where around 110 to 115 motor and esc temps where well below danger levels. 100 & 98 if memory serves..
