How many turn fins on mono
  • boater76
    • 505
    How many turn fins are on a mono and which side?
  • boater76
    • 505
    Oh and is a 78mm rudder good for a 20" mono?
    • m4a1usr
      Fast Electric Addict
      • 2038
      Not all monos need a turn fin or a set of them to handle adequately. Just like trim tabs. Not always needed. It depends on what hull you are running. All that said,...most folks normaly turn to the right so thats where they put on a turn fin. What hull are you setting up?
      John
      Change is the one Constant
      • boater76
        • 505
        BBY Warzone Jr. 20" long 5.5" wide with 3600kv on a 3s. with a Stinger strut and not sure about rudder. I have a 78mm but not sure if that would be long enough or would a 95mm be better?
        • m4a1usr
          • 2038
          I like about an 1.25 to 1.5" of rudder below the strut on most of my setups. But you have a small hull so I'm pretty sure thats too much. Desired speed would an important consideration. Someone with more experience should chime in.
          John
          • hydromaddicted
            • 83
            30mm below on my el lobo 21 inch
