5mm rotor shaft replacement
  • steveo
    • 1454
    i have a hacker c-50 motor with a broken rotor shaft does anyone know where i can find 5mm steel solid rod to replace the shaft with
  • NorthernBoater
    • 811
    I think hacker can service that. Send an email to this address [email protected].
      That is not a simple do it yourself repair, it needs to be replaced by Hacker. I sent in a B50 earlier in the year and the new rotor was around $120. Remember that the magnets are on that shaft and cannot be removed simply.
      • steveo
        • 1454
        i easily removed the magnet, it was just pressed on, and for a $120 i'd rather fix it my self, which i think can be done with right parts, maybe i'll find a someone to turn down a piece of steel at a shop.
        • steveo
          • 1454
          well maybe i will give hacker a try first, thanks guys
          • Doozie870
            • 828
            Some of the electric helos use a 5mm shaft for the main rotor, check your lsh for replacement parts.
              Suit yourself. Removed/installed incorrectly, the magnets can and will crack or come loose from their mountings. If the magnets come apart at 40,000 rpm your entire motor is ruined in a millisecond. Been there - done that!
