Something is wrong with boat
  • RC Mechanic
    • Jul 2007
    • 73
    I had this RC boat awhile back that got me into rc boating. It was a tpy rc made by nikko called the Tigershark. Anyways after I happened upon a villian EX it has rarly been used. The hull is very simple so I ripped out the stock electronics and installed hobby grade electronics. I got it ready for its first run in the water today with its new innerds. I pot up on plane and the boat immediatly started to roll to the side. I repeated this and everytime that I got up to speed it started to roll badly, once it nearly capsized but it rolled back over. ANy clue what is going on?
    I don't plan for this boat to be a speed demon or anything, just a fun project.
    It is running a 540 motor with direct drive to the stock driveshaft and stock prop. Has a mini traxxas steering servo and it was running on a 6 cell 2400mah Nicd battery. ANy clue what is going on? My only guess is torque roll. The boat is (off the top of my head) around 4-6 inches wide and about 20 inches long.
  • Doug Smock
    Moderator
    • 5272
    Can you post pics??? Did you change the motor?? Does the boat rise high up out of the water before it rolls, or is it rolling as it gets up on step?
    Doug
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    • RC Mechanic
      • Jul 2007
      • 73
      I changed out everything in the hull except for the hull and the drivetrain and the rudder. The motor is probably twice as big as the original. It seems to roll when it gets up on plane, however I found a few times that I could fight it with the rudder by steering in the oppostie direction of the roll.
      I didn't have any roll problems at lower speeds though
      • Doug Smock
        Moderator
        • 5272
        It could be lifting itself too far out of the water. Try a smaller prop if you can.
        Can you post a picture of your setup?
        Doug
        MODEL BOAT RACER
        IMPBA President
        IMPBA 19887L CD
        NAMBA 1169
        • RC Mechanic
          • Jul 2007
          • 73
          Ill get a pic in a bit. The prop is already pretty small. I can't change it without further mods. Like I said this is a toy boat. I could change the prop but I would have to swithc out the wole driveshaft wouldn't I?
          • Doug Smock
            Moderator
            • 5272
            Maybe so. Can you just reduce the cell count?
            Doug
            MODEL BOAT RACER
            IMPBA President
            IMPBA 19887L CD
            NAMBA 1169
            • evofan74
              • Jul 2007
              • 45
              The pic will tell us alot more to try and help. Take a couple from dif angles.
              • RC Mechanic
                • Jul 2007
                • 73
                Okay well I found these pics in my photobucket account. They aren't completly up to date. The only difference in them is now I have build a wooden batteyr bow and installed it, and I put the esc and RX in there. ALso I wasn't using that 7 cell sxs gp3300 pack. I was using a 6 cell 2400mah Stickpack.
                Heres all the pics I have, if you need to see anything elsee just LMK.
                • RC Mechanic
                  • Jul 2007
                  • 73
                  • Doug Smock
                    Moderator
                    • 5272
                    I think your boat is over powered. What motor do you have there?
                    Doug
                    MODEL BOAT RACER
                    IMPBA President
                    IMPBA 19887L CD
                    NAMBA 1169
                    • saleens7
                      • 1108
                      you could just move the batt to the side of the boat lifted up by the roll (should be the left side if looking at the transom)...it may sit strange in the water when still, but should keep it fairly level when up to speed...my OM21 had a similar problem...not as severe, but the hull is close in size and it runs on a 540 and 6 cells....i moved the batts more to the left of the hull...problem solved...
                      • RC Mechanic
                        • Jul 2007
                        • 73
                        All I know about the motor is that it is a 540 and it is a stock ROAR legal motor. This guy sent me it for free one time along with a few other things.
                        WOuld the motor being located up front have anything to do with it?
                        Thanx, ill give it a try as far as moving the battery over. How far doyou think I should move it? ABout 1/2 inch?
                        • Doug Smock
                          Moderator
                          • 5272
                          That is a 27 turn motor then. You need to reduce the cell count since you can't change the prop. Moving the batterys may help but I suspect you will burn the motor up with that prop. What esc do you have? It may be at risk also.
                          Doug
                          MODEL BOAT RACER
                          IMPBA President
                          IMPBA 19887L CD
                          NAMBA 1169
                          • RC Mechanic
                            • Jul 2007
                            • 73
                            Its an old Novak foward only. 410-M1 if im correct. Its not water cooled. So you think its a 27turn motor? I have a 23 turn 550motor that should fit fine and will probably run at a bit less RPM. SHould I try that? If not what about a traxxas stinger 19t?
