Hello everyone, I need some input for a Mean Machine project, I heve a new electric version of the hull from OSE and I'm leaning towards a Castle 1515 1Y with a Hydra 240 lv and 2 Trunigy 5000 mAh 4s 40C. Looking for mid to high 50's for speed. What about a 1518? Also should I run a .150 flex cable or .187 flex cable?
Mean Machine motor input
The 1515/1Y is a great hydro motor, but IMO it is not the best for a cat. You'll have better luck with a motor with a bit more torque to swing a bigger prop. What kind of run time will you be wanting, a 55 mph MM will not run for five minutes at full throttle, that is really a racing setup.
If you want to go with Neu, a 1515/2D, 1518/1Y or 1521/1.5D will get you past 50 mph with an m645 prop, assuming you have the cat set up well. If you can give up 5-7 mph, a Feiago 8XL or 9XL works great in these hulls. Either way you'll want to run a 3/16" cable, you'll eventually snap a 0.150" cable running in the 50s.
