Normally does back cutting a prop reduce prop lift? Also a higher Rake prop does that do the same thing. What cost to performance does it efect.
Quick question on prop
The following are very informative.
http://www.lake-link.com/boating/props101.cfm
I strongly recommend NOT to Barr-cut the trailing edge. That is a fuel boat mod and does nothing for an FE boat. Every prop I have with the Barr cut - even those done by experts - has cracked at the bottom of the relief.
Thanks Fluid. The rcboat.com site I used before but was not sure if it was to "outdated".I always like to try something different and i need to reduce some lift in the props i use.PT-45, 109mph, finally gave up after last bad crash
H&M 1/8 Miss Bud 73 mph
Chris Craft 16 mphComment
