Hi All,
I have a fairly crude FE monohull that I built myself and am running a 12 Cell Brushless Setup ( http://www.offshoreelectrics.com/pro...=dh-aqcom-1800 ) I recently upgraded it from a 700BB motor and the brushless setup is much faster/more fun to play with.
I have dialled it in reasonably well using a set of carbon props, and have ended up with the 45mm 1.4 pitched prop giving the best performance, 42mm props (both with 1.4 and 1.6 pitches) run very poorly and a 48mm one generates way too much motor/battery heat. The 45 has good performance and heat generated is manageable but perhaps slightly higher than I would like it to be.
My question is, will upgrading to an x445 sharpened & balanced prop yield any appreciable improvement in performance and/or run times or is the difference between like carbon vs beryllium prop fairly negligible?
I'm Just looking for ways to tweak and improve performance further without needing to resort to full rebuilds.
