I've been running the standard OSE water cooling jacket on the sv27 motor. After a nasty rollover one of the cooling line fittings was knocked out. I've glued it back in place several times, but it usually comes out again.
Any of the other OSE water jackets fit the sv 27 motor, in particular ones with threaded hose fittings? Like the ul-1 jacket?
Just a side note, that after multiple times at re-epoxying the fittings in place, finally enough seeped down around the opening to block off the water flow substantially. Then when I went to remove the jacket...it was pretty much impossible to get it off.
larry
larry
