I posted earlier that I had a KD45XL that came with a bent shaft. It was only bent from the case outward, probably dropped at the factory and shipped anyway because the package came to me undamaged. I was sent a replacement, but needed two motors for a 42" twin Cat I am building. I'm sure there are a lot of ways to do the repair--I had several in mind. Just for giggles I made a tool out of a 10' piece of hard round 3/8" stock I had. I bored one end to the 6mm of the motor. I chucked the motor housing in my lathe carfully and spun it to check for trueness. With the lathe off, I brought the live center over as a guide. With the 10" rod on the shaft, the bend is exaggurated and I used the leverage of the long rod to gently bend the shaft until it was lined up perfectly with the live center. It took about 5 minutes or less and it is perfectly straight. If you get it straight with a 10" extension--its perfect as a 3/4" long shaft--- believe me! Some may not agree with the repair, but it spins free and feels in balance and I now have a second motor for my project. I don't know if this can be done on a mini Lathe, but mine is full size. Some of you may want to give this a try if you have a motor that may have been dropped or bent in some other way.
Russ
Russ
