[QUOTE=nosybody;153386]I've read from some forum that suggested using solder with silver instead of your typical 60/40 tin lead electrical solder. Silver also has a much higher melting temperature then tin/lead. You will need a super big hot iron to melt that sucka into the lug and that thick heat sucking copper wires along with some flux to make it flow right. I think your problem is due to your iron not hot enough for the solder to really covers all the inside between the copper and the lugs. I've done much soldering with electronics circuit boards and electronics components and notice that thicker copper wires tense to draw the heat away from where you wanted to solder, this is due to the thermal conductance of copper. This will result with a "cold soldering joint", a term electronic people calls it and will results with increase electrical resistance.
For the price of a Lehner, I could have gotten 2 Neu instead. Do you suppose Lehner are over rated for their high prices? Then that would be true with Plettenberg too.
I had trouble communicating with those folks at Lehner by email, probably because english is not their first language. I notice when I ask more then one questions per email, they only answer one of my question and not the rest. I realizes that I have to keep my question short and simple because their reply are also short and simple.
Here are their plugs > http://www.lehner-motoren.com/preise.php
You can also get them from > http://www.finedesignrc.com/motoraccessories.asp
BK Motor/ESC Plugs.
They 5.5 mm and can handle 200 amps! These are as good as it gets. Made specifically for hi amp applications!
$5.50 a Pair
(1 male, 1 female)I USE 94- 96 PERCENT SILVER ( NO LEAD, OR ROSIN CORE)AND A 100 AMP IRON. THE TWO WORK REALLY WELL TOGETHER! 5.5 MM? I USE QUITE A BIT OF AND EVEN USE 8MM ON MY MARITIMO PACKS AND ESC'S...GOT TO SUPPORT YOUR COUNTRY WHEN PRODUCING EXCELLENT PRODUCTS LIKE NEU! YOU PAY FOR THE AMERICAN QUALITY AND CUSTOMER SERVICE, AND I THINK THEY PACK A WAY BIGGER PUNCH!!!
BK Motor/ESC Plugs.
$5.50 a Pair
