Wiredrive question?
  • Tuslow1
    • 154
    Wiredrive question?
    My new drives say that they are pre-drilled for 2mm universal wire...
    My question is what size wire matches 2mm??? .062 or maybe .078?
    I really want to build with piano wire and I want to use .078, so is 2mm the same as .078 or do I have to open the holes more for the wire size I want to use?
    Thanks for your help, Ken
    OK, You Go First!!!
  • Jeepers
    • May 2007
    • 1973
    according to the chart I just read .078 is 1.9812 mm, close enough.
    • Tuslow1
      • 154
      Thanks Jeepers
      Next question: What do I use to hold the wire into the propshaft???
      Something tells me superglue won't work....
      OK, You Go First!!!
      • CornelP
        • May 2009
        • 745
        Read this article... very informative... Loctite 603 is the way to go...
        • Jeepers
          • May 2007
          • 1973
          Loctite 603 works great! I have also used Loctite 640 as well and have never had a failure.
          • Jeepers
            • May 2007
            • 1973
            Originally posted by Tuslow1
            Thanks Jeepers :
            your welcome
            careful now your gonna squeeze my brain out of my ears!
            • CornelP
              • May 2009
              • 745
              Forgot the link:
              • Tuslow1
                • 154
                LMAO!!!
                OK, You Go First!!!
                • Tuslow1
                  • 154
                  Highly informative, CornelP, Highly informative!
                  I had a deadset fear of building my boats, but the helpfullness and knowledge of fellow members tend to make the hard and impossible seem quite simple and easy. Thank Gosh I finally started asking questions or all of my boats would have continued to be very expensive customs or cheaply made RTR's....
                  OK, You Go First!!!
