When is it time for bearing replacement?
  • FE Wannabe
    • Jul 2007
    • 626
    I have a kinda newbie question.
    What are all the factors that determine when you should replace the bearings in a brushless motor?
    I know when bearings "feel" rough they need to be replaced, but what about end play on the rotor? How much is too much?
    I have some motors with no end play and some with as much as 2mm and a few in between.
    Thanks for any sage advice.......
    Brad
    SoCal Fast Electrics|H&M Drifter S-CC1512/4S/T180A|Aeromarine Scorpion 32"- UL-1/4S/HM200A|Insane 34- CC1515 1Y/4S2P/T180A|BK Bandit S-CC1515 1Y/4S2P/T180A|Insane FE30 UL-1/4S/ETTI 150
  • domwilson
    Moderator
    • 4408
    Side play, a grind when turning the shaft, unusual noises or whining when running, rust. There are other symptoms. Just can't think of them right now.
    Government Moto:
    • m4a1usr
      Fast Electric Addict
      • 2038
      Brad
      End play has more to do with rotor gap then bearing wear. To take up end play you need to either place spacers in between the two bearings on the end plates or install a thrust bearing that takes out all end play. Simple to do but you need to understand where the force will occur as one side will be loaded while the other will not.
      John
      Change is the one Constant
      • jcald2000
        • May 2008
        • 774
        If you wait until you can hear/ see something, it might be too late. I replace every 50 races or about every other year.
        • Steven Vaccaro
          • 8723
          Jim I agree, waiting to long can be disastrous for the motor. The tolerance between the rotor and windings is very tight. If you loose a bearing during a run, most likely the rotor will go off center and hit the windings. then its
          Steven Vaccaro
          • FE Wannabe
            • Jul 2007
            • 626
            Thanks for all the replys, the advice is appreciated.
            Brad
            • graill
              Retired
              • 389
              This is good advice. Manufacturers should supply you specs on anything you want, including the bearing and bearing manufacturers, from this you can plan a preventive maintenance routine based on your level of activity (how rough you play) and usage times on the parts.
              Waiting for something to show up as worn or until something starts to fail is totally up to you and your own wallet.
              Replacement should be based on time (your spec'd usage) not wear or failure.
              • Gary
                • Jan 2009
                • 1105
                I have found recently that when the motor is at full tilt beyond its limit and locks up soild out on the water that its probably time for new bearings!!!!!!!!!LOL Goood Times!!!
                H&M 1/8 Miss Bud 73 mph
                Chris Craft 16 mph
                • FloatDaBoat
                  Bare Bones Fabricator
                  • Sep 2009
                  • 368
                  From Full Tilt Boogie - - To Total Carnage !!!
                  Oops . . . .
