Cutting the shafts...
  • vvviivvv
    • May 2009
    • 1082
    I just got my Neu 1521's the other day and the shafts are about a inch and a 1/2 long, this is rather awkward for my boat, what do i have to be aware of when i cut them? heat build up ruining the bearings? anything else? i know i cant let any of the shavings get inside the motor so it will be taped up, could cutting the shafts cause it to be thrown out of balance?
    Uk SAW record holder
  • westbeach
    OSE Rocks!
    • 951
    Cutting the shaft won't throw it out of balance unless if you force the cutting tool while cutting. Use a cutting disc with some cutting oil. Don't let the shaft heat up too much while cutting or it will change the temper. Better yet, find a machine shop with a lathe and get them to grind a flat spot for you too!
    HPR115 x2 ,Dark Horse Shovel, Delta Force CyberStorm, Delta Force Sniper 23-RTR:
    • m4a1usr
      Fast Electric Addict
      • 2038
      You wont imbalance the rotor by cutting it down but the old adage applies. Measure twice, cut once. You need to answer some of the most basic questions before chopping off your drive line. Do you plan on running a thrust bearing? Its a good idea to use one if you have any doubt. So you will need to compensate for bearing length and depending on what motor face plate you got do you need to attach a bearing load spacer? Those 2 items can add up to 1/4" of rotor shaft that should not be removed. Need a pic to understand? Let me load one up.
      John
      Change is the one Constant
      • m4a1usr
        • 2038
        John
        • RayR
          @SiestaKey.calm
          • Jun 2007
          • 1518
          When you cut the shaft, put it in a plastic bag with the shaft poking through a hole in the bag. This so the metal bits don't end up stuck inside the motor.
          Ray
          • vvviivvv
            • May 2009
            • 1082
            i have access to a machining shop but i dont understand how you would machine the shaft that way? put the motor in the machines chuck and use the tools on the shaft? just use a parting tool ? wasnt planning on a thrust bearing tbh there isnt any play in the motors
            • detox
              • Jun 2008
              • 2318
              Whar size are the shafts? 5mm or 8mm?
              • malibu1
                • Sep 2009
                • 74
                The shaft is an inch an a half long? Thats sounds way to long. The shafts on my 1527's are 3/4 of an inch long.
                • vvviivvv
                  • May 2009
                  • 1082
                  there 5mm and yeah even Jim Williams who sold me them was curios about the length ill take a pic if u dont believe me..
                  • malibu1
                    • Sep 2009
                    • 74
                    V, I believe you buddy! No need for a pic. I just had not seen a shaft that long. I have seen lots of crazy things happen during manufacturing processes in the last couple years. You would think that there would be some kind of QA inspection on these motors before they are sent out the door.
                    • motoxbob11
                      • May 2007
                      • 190
                      When I got my 1521 I couldn't believe how long the shaft was either. I decided to cut it down because the coupler would have looked lonely way out there on the end. Dremel cutoff wheel worked great and also Dremel to grind a flat spot on the shaft.
                      • FloatDaBoat
                        Bare Bones Fabricator
                        • Sep 2009
                        • 368
                        There seems to be quite a few of these "Inspectors" out there. They probably spend most of their time bragging to fellow employees that, "I put the "K" into Quality Control!!!).
                        • malibu1
                          • Sep 2009
                          • 74
                          LOL, and complaining about the Engineers:)
                          • toysRme
                            • Jul 2009
                            • 75
                            I also used "blutak"(poster gum) or Serpent cleaning gum to sheild the bearings and plug the breather holes in the endbell. This was great for holding the plastic bag on the shaft.
                            Take your time and trust the skills you have, First one is the hardest.
                            STUFF NITRO GO LIPO FASTELECTRICS.COM
                            OFF-SHORE-ELECTRICS.COM
                            INVENTOR OF LITHIUM CELLS:bowdow
                            • vvviivvv
                              • May 2009
                              • 1082
                              going to take it to school with me tomorrow see what can be done on the lathe, might have to fashion something out of solid aluminum to support the motor in then taper it down so it fits in the supporting thing of the lathe alot of machining to do tomorrow while the 5mm shaft goes into the spinney chuck
