When programming a brushless Esc from NiMh to lipos, does it only activate a low voltage cutoff circuit (LVC) or does it do anything else?
brushless ESC programmig
JohnChange is the one ConstantComment
During discharge the weakest cell (highest IR/lowest capacity0 is going to drain the first. The strongest picking up the slack. All multiple cell packs have this issue. No 2 cells are identicle. The best we can hope for is the tolerance is so close that the worse one isnt all that bad.
John
all my cells are turnigy or zippy,they say on the front of the cells ohm matched
thought this more a sales thing but maybe the do match them and it makes a diffrenceComment
Quality made packs are matched. But there are plenty of examples where packs have had a failures related to a single cell degradation that most likely the explanation is one of them was a lower quality or mismatched. And of course theres always the issue of the one cell thats furthest from the rest that see's the most resistive path due to wire length,solder joints, etc that has the effect of having to overcome the problems when dealing with a series circuit. That outer cell is going to always be subjected to the worse effects when in discharge.
