I sent an email to Grim, but also wanted to see if any of you tried to run the stock SV27 or UL1 escs on 2s or 3s lipo?
SV or UL1 Esc's on 2s?
Tags: None
Mike had a thought to try to disconnect the red wire for the bec and run a rx pack to see if it arms. Just a thought. Mainly I was thinking of a single 3s pack.Steven Vaccaro
if it has a low cutoff set for 4s wouldnt the lvc voltage be higer than a fully charged 2s pack,if that makes sense
The SV27 esc doesn't have a LVC. The UL-1 has one but I'm pretty sure it doesn't have anything to do with the operating voltage it's set at 8.4v for some reason.
I've been thinking about running two 4 nimh batts to get the 8.4v
My Sv esc arms with 2s. I never ran it on 2s but I do run it on 3s on a regular basis with no problems.If all of your wishes are granted, many of your dreams will be destroyed!Comment
It was once said in another thread that the lvc was a auto detecting method that decides how many cells you are using. Not sure if thats true or not.Steven Vaccaro
Steven Vaccaro
Yes a 7.4 & 11.1. I used to use it in my SV with 3s 5000 to go wave jumping and it was fine. I now have it in my mini hydro and I run that on 3s 2200. I use a Dimension Engineering cutoff. I have bench tested the mini with a 2s and it armed and ran. Never had it in the water with 2s though.If all of your wishes are granted, many of your dreams will be destroyed!Comment
thanks a ton!Yes a 7.4 & 11.1. I used to use it in my SV with 3s 5000 to go wave jumping and it was fine. I now have it in my mini hydro and I run that on 3s 2200. I use a Dimension Engineering cutoff. I have bench tested the mini with a 2s and it armed and ran. Never had it in the water with 2s though.Steven Vaccaro
