I've got a couple of nihm packs that were completely under water for about 3 hours. Is it a good idea to try to recharge them to see if they can still work or should I just toss 'em?
One thing to watch is the vents, nimh cells have safety vents. The vents are there so if the cells need to vent the gas, they let it out quick. These vent could now be a problem area.
my first FE boat (tunnel hull) sank in a pond,it was in 20 feet of water for 8 days
lucky it was fresh water,it had two matched nimh packs in it the only thing i lost was the servo,everything else was okay after a good dry
I cut open the shrink wrap to let them breathe better (and to help evaporate the water).
One of the packs just charged to 50% on a 0.8A trickle... hoping it will improve after a few cycles...
then i put it on a slow charge and it's as new for months now
only the label is a little water stained
i forgot all about that little trick! Thanx!
I'm rjuvenating a sunken lipo pack as we speak,I'll post results. I'm forcing power into it on a Nimh charger
I cut the shrinkwrap open and let them dry out, they both took a full charge-- just got back from a great run.
I used glad press and seal wrap and a bit of electrical tape to seal up the batteries while they were in the boat-- then I take it off and let em' air out when I'm done.
Note, I had purchased 5000mah venom packs the other day-- one pack would not take more than 30% charge (even at 0.8A charge), and the other one completely overheated during the first discharge and blew the vents-- split open the shrink wrap and all...
