Well I am working on an outboard cover that will go around the strut making it appear to be a big merc outboard. These will be vac formed and then put together and painted. The main issue is mounting it to hold up to flips. Foam will be inside of it so they will not sink.
Jeff,
When will these Merc covers be ready for purchase?????
I am about to make some plugs. Not sure what version I will do. I could make them in FG but I really think Vac molded will be fine. I do not want them to cost much. The main work is getting a decent mounting configuration.
I mainly wanted to make them for the struts to make them look like OB but then I got to thinking about the LU that OSE sells and thought it may be a neat deal.
For that one I would need a lower unit and be able to mount a motor and cooling jacket for fit.
Maybe I can talk Steve in to sending me one and then he can also offer them.
That is what I am working on. Not sure I can offer them for every lower Unit but we will see how the first go. I like OSEs new one he selling. Probably one of the better units out there.
It will be a bit as I have to get geared up. I suspect they will be painted and ready to install. With Merc decals and all. As close to the pictures I can get.
if the foam was molded in side the cover it would make it stronger and the foam could be used to hold the cover on to the motor,fit it on like a sock.
a small tether cord could be fixed from motor to cover incase it comes off.
just acouple of thoughts
