flex for REK
  • JimClark
    • 5907
    flex for REK
    Can anyone tell me if the flex shaft for the REK is the same size as the Hyperperformance that Steve sells?
    Jim
    Billy Graham
  • properchopper
    rcgoatbuild@snotmail.com
    • 6968
    Jim, in most cases the important dimension is the end-play between the motor collett, the shaft, and the prop driveshaft. I've always had to shorten the motor shaft to get the right fit and allow for some endplay. Just how much shortening may vary depending on the motor-to-lower unit adaptor being used.
    • JimClark
      • 5907
      I would assume you would want the motor as low as possible? So yo might end up shortening the cable?
      sorry I am a tunnel hull dummy
      I admit it I am a hydro geek
      Jim
      Billy Graham
      • ozzie-crawl
        • Sep 2008
        • 2865
        according to hyperformance they only sell one cable,say it fits rek and bullet drive
        • properchopper
          • 6968
          The cables that are sold ready-made are square at both ends and can only be shortened very little so that they stay mated into the motor collett and propshaft. I have seen some builders like Dave Newland and Mike L ( who has the Shaman build thread) use Octura couplers on the motor which allow trimming the square end off the motor end of the shaft. They made their own spacers to fit. In all cases, the lower the motor, the better, of course.
          • ozzie-crawl
            • Sep 2008
            • 2865
            dont know if this helps but there are places about who specialise in cables for 1.1 boats,throttle and speedo.
            we have one in town and they have .150 flex left and right hand,they cut to lenght and sqaure the ends. good if your stuck for cable in a hurry
            • JimClark
              • 5907
              Great info thanks guy's
              Billy Graham
