Has anyone blown an ESC with...
  • BHChieftain
    Fast Electric Addict
    • 1969
    ... a basic 3S x 2 Lipo running parallel or serial, or with nimh 4200 x2 parallel or serial?
    -Chief
  • tth
    • Apr 2008
    • 1510
    I personally have not but if any ESC is pushed beyond its given values.............
    It really is not enough info on what kind of ESC we are talking about.
    • Flying Scotsman
      Fast Electric Adict!
      • Jun 2007
      • 5190
      Chieh, as tth mentioned, what hull, what prop, what is a basic 3S X 2 Li-PO and as tth mentioned what ESC??
      You will blow any ESC if you exceed their stated specifications and even then reduce those specifications by 30% and that is important for cheap Chinese ESC'S. Look at some of the build threads
      Douggie
      • wolf IV
        • May 2008
        • 961
        Ive got a 1 gal. Bag full of fried esc's!!! Literally... Just buy a few 200 amp himodel esc's and dont worry about it :) this is the way i do it ...lol..
        http://www.youtube.com/watch?v=e-npTLBHefY
        • egneg
          • 4670
          Do you mean like this ...
          IMPBA 20481S D-12
          • BHChieftain
            • 1969
            I'm talking a stock ESC and motor for a fastech,
            -Chief
              I don't own a Formula Fastech, but the owner's manual clearly states that 21 volts is the maximum input voltage for the ESC. Running two 3S packs in series will greatly overvolt the ESC (25.2 volts), and I can imagine the ESC would be damaged or eventually destroyed. Running the 3S packs in parallel may not supply enough voltage to turn the ESC on. 12 NiMH cells in series is the recommended battery power.
              There is also this warning:
              Caution: It is imperative that you do not attempt to use LiPo batteries in the Formula Fastech 26 Brushless unless it has been
              properly programmed or serious damage to the batteries and electronics may occur.
              • wolf IV
                • May 2008
                • 961
                • Ctonez
                  • Jul 2007
                  • 404
                  -Chief
                  2 x 3S is too much for that system. w/ Nimhs, 2 x 7cell packs will likely be okay, but performance mitigated by the extra weight. 2 x 2s LiPo packs is probably the best option for stock ESC and motor. I don't own one either...apparently you'll need to program the ESC for Lipo...?
