Coupler trouble
  • slapahondn
    • Dec 2009
    • 70
    Coupler trouble
    Does any one know were i can get a coupler that connects a 5mm brushless motor to a 1/4" square flex shaft cable. I have looked every where for one with no success. Thanks, Ben
  • Jeff Wohlt
    • Jan 2008
    • 2716
    I can make you one. I just made someone else one. It is set screw style with 6 on the cable and 2 on the motor.
    It looks like this one but 5mm.
    www.rcraceboat.com
    [email protected]
    • slapahondn
      • Dec 2009
      • 70
      Perfect!!! How much for 2 shipped to Miami?
      • bwells
        • Jan 2009
        • 842
        Ben, don't mean to jack your thread but Jeff, can you make a coupler that is 5mm to .130 as well as a shim for the stock bj shaft to do 3/16 props with a hole for the drive dog set screw. PM me and sorry Ben for riding your thread but had to do it. Brian
        • Jeff Wohlt
          • Jan 2008
          • 2716
          Yes I can. I guess you are talking about a 4mm ID tube with a set screw hole and for the drivedog.
          Or, you can also just use brass tube to step the prop shaft up to 3/16"
          They make a flex hex coupler for this if you want one of those.
          www.rcraceboat.com
          [email protected]
          • D&D
            • Aug 2009
            • 185
            I'm confused, why would the square drive flex cable be attached to the coupler? Isn't the object to have a floating square drive system with the square end of the flex cable floating in the coupler and the other end sodered to a ferrel??? If anyone is building a square drive coupler (attaches to a 5MM motor shaft and allows a square drive shaft to float in the coupler) I would be interested in purchasing such a product also.
