Okay,
here is the situation.
I have an old MRP budweiser electric tunnel hull (22" vacform version) running with the following setup: Aquacraft EP1 outboard, Feigao 540s 8t motor (4700kv), CC hydra 120, hyperion 3s 2200 mah x2, in parallel (11.1 volt @ 4400mah), octura x430. this boat is pushing 50mph when it stays on the water.
it does pull OVER 120 amps, however, so i want to change things around a bit.
my thinking is to go with a Feigao 540s 16t motor (2400kv) and switch the batteries from parallel to serial (22.2 volt @2200mah).
according to FEcalc this will drop me down to 66 amps, but increase my speed from an estimated 49mph to 52 mph.
having said all that, which ESC should i go with? I would no longer need to spend $180 for a CC hydra 120, but what is there in the 70-90 amp range with good quality?
thanks
Tim
thanks
Tim
