Batteries for Titan 29?
  • Unsullied_Spy
    • Nov 2008
    • 91
    I am looking for batteries to run in my Titan 29 running a 70mm 2000KV Medusa on 4s, I am going to start with a CF45 prop and go from there. I was looking at getting a pair of 4s 4000 mAH 40C Turnigy lipos from HobbyCity and running them in parallel but I have no idea how heavy I can go before performance starts to suffer. I run in mostly calm water, so extra weight to hold it down in the chop isn't a big deal but I hate recovering boats so I want it to be stable. I would like to go as big as I can for the best run times but don't want to drag around too much weight. Any thoughts or recommendations on batteries?
  • Rumdog
    • 6453
    Those batts would rock! Don't worry about the weight, you'll want a lil weight in her to keep her stable. If you are sport running, you could give 5s a whirl too, just prop down and watch temps!
    • Unsullied_Spy
      • Nov 2008
      • 91
      OK, thanks for the advice! 8000 mAH 40C lipo would be awesome for run times. 5s puts me at about 37,000 RPM with that motor, that would be a blast but I think I should learn to drive and tune it on 4s before stepping up to nutso speed. As long as I'm getting 35-40 MPH out of it I think I'll be fine. I may run my 2 2s 8000 mAH Maxamps lipos in series at first until they die (they're Maxamps packs with 60-70 cycles already on them, they surely won't last boating abuse very long) then decide if I want to run 4s or 5s.
      The big issue with 5s is heat, but with a Medusa motor on it's own water cooling circuit and my Etti 150A on an independant circuit I should have some headroom for props. I'm still new to boating, I've got lots of experimenting to do come Spring
      • Jeepers
        • May 2007
        • 1973
        2x Hyperion G3 35C 7.4V 6500 MAH
        • Jesse J
          scale FE racer
          • Aug 2008
          • 7116
          I got upper 30s with a pair of 4S, 25+C elite 4800 mah packs in parallel with significant run times and no heat. With calm water you can air it out significantly and not be bothered with extra weight/drag issues. You gonna love this baby!
          "Look good doin' it"
          See the fleet
          • Jeepers
            • May 2007
            • 1973
            Originally posted by Unsullied_Spy
            As long as I'm getting 35-40 MPH out of it I think I'll be fine. I may run my 2 2s 8000 mAH Maxamps lipos in series at first until they die (they're Maxamps packs with 60-70 cycles already on them, :
            Yo should get 40+ in a Titan 29 with that motor on 4s easy.
            I guy here ran the Medusa 36-60-2200 motor on 4s in a 37inch 9lb hydro Gpsd repeatedly in low mid 50s with the no heat. that 36-70-2000 should have no problem moving your much lighter titan 29 to similar speeds
            • Unsullied_Spy
              • Nov 2008
              • 91
              Sounds good, I'll start off with my Max cramps lipos and go from there. Performance on 4s sounds like it's about what I'm looking for (and could probably prop up a bit with that Medusa). This weather is killing me, wish I could get into the Swim Center to test it out...
              ~40 MPH is perfect, OSE and Jesse both say the hull is only good to about 45 and with this boat I just want a fun driver, I have a tunnel hull that I'm building up as a speed machine.
              Good to know, thanks! Know anyone looking for some Medusa motors? I may keep this 70mm but I have an 80mm 2000KV that I'm thinking of selling.
              • Jesse J
                scale FE racer
                • Aug 2008
                • 7116
                Whats wrong with 2' of ice on ponds and -20deg F? We might have to look into submarines with wireless spy cams....
                Actually, the Madison might have some open spots..... well maybe not after this arctic week.
                See the fleet
                • Unsullied_Spy
                  • Nov 2008
                  • 91
                  We should look into building ice racers, either wind powered or have little pusher props on them and race across the ponds with them.
                  I'm a little apprehensive about running boats in a river...too many things can go wrong and cause me to lose it. I have pretty bad luck so far with boats, I'd rather not take my chances. Maybe I'll take a few laps around the hot tub.
                  • Alfa Spirit
                    • 2131
                    EC Power are good quality high capacity batteries
                    • Jeepers
                      • May 2007
                      • 1973
                      Spy, a 540 9XL 1898KV on 4s, with a x442 will get you 40+ easily, that Medusa will push that hull easily 40+ on the same prop.
                      • Jeepers
                        • May 2007
                        • 1973
                        How much?
                        • Unsullied_Spy
                          • Nov 2008
                          • 91
                          Sounds good! Jesse gave me a CF 45 and CF48 to go with it, but in the future I was thinking of picking up a 440, 442, and a Prather 220 and playing around with the different props.
                          How much?
                          $100 shipped. It's got some hours on it but I think the bearings are still fine, might want to replace them just to be on the safe side.
